PLX Stopped communicating
94vt3c
Re: PLX Stopped communicating
Post by 94vt3c »
Sorry digital connection looks wrong in the first photo. Here is a better look with it disconnected. Again shotty wiring is temp.
1994 CIVIC EG COUPE(EJ1)
K20A2 Boosted E85
Kpro4 PLX Wideband
What has changed in the car since the last time it worked. Is the ethanol content new?
94vt3c
Post by 94vt3c »
Nothing changed. Just battery was low voltage and it struggled to start. Started on the 2nd try and boom no sensor detected. Ethanol content has been setup for a long time
K20A2 Boosted E85
Kpro4 PLX Wideband
Have you tried reuploading your calibration to the ECU?
94vt3c
Post by 94vt3c »
Yes. Tried a few known good calibrations
K20A2 Boosted E85
Kpro4 PLX Wideband
Do you know anyone else with a K-Pro?
94vt3c
Post by 94vt3c »
Unfortunately no..
K20A2 Boosted E85
Kpro4 PLX Wideband
Was any other work done on the vehicle since the last time it was working correctly...even if it was an oil change, tire change...anything.
94vt3c
Post by 94vt3c »
Absolutely nothing. Parked it working fine. Sat for a few days then my current predicament happened.
K20A2 Boosted E85
Kpro4 PLX Wideband
If you unplug the ethanol contend input does it read the wideband?
94vt3c
Post by 94vt3c »
I will check it when I get home from work. Question though why would that affect it? Flex sensor has been installed since I got the kpro and is functioning properly.
K20A2 Boosted E85
Kpro4 PLX Wideband
I'm just checking other things here.
94vt3c
Post by 94vt3c »
Same result. No sensor detected on digi input.
K20A2 Boosted E85
Kpro4 PLX Wideband
94vt3c
Post by 94vt3c »
Any other ideas to troubleshoot? I'm stumped here..
K20A2 Boosted E85
Kpro4 PLX Wideband
The only thing left would be for you to send the PLX and your ECU to us for testing here.
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread
