Wiring up AEM 30-0300 wideband, need help!!
Re: Wiring up AEM 30-0300 wideband, need help!!
hj121600
Post by hj121600 »
Again thank you Spunkster for getting back.
After checking my ECU most of the pin outs I can't use for some sort of reason
D14 is out because as you mentioned it doesn't supply enough voltage
D12 is out because I don't have anything is C42 on my ECU
D10 is out because I have R136/R138 filled and I'm not going to touch that
B6 is out because I have R2/R3 filled and again I'm not about to touvh that
I do have v3 can I use the Analog cable that came with it? They say they supply 0-5v but again I"m new to all this so there may be something I don't know/understand yet.
Thanks again
D10 can be used, you only need to cut one let of the resistor, it can be re-soldered later if you want or need to.
DaX
Post by DaX »
Just cut the resistors and use D10. It's super simple.
hj121600
Post by hj121600 »
Thank you guys. I will find a small pair of snips and give cutting those a shot.
AndrewJ
Post by AndrewJ »
Alright so I wired my wideband wire to d10 and changed it on the close looped advanced but when I datalog, the afr bounce from 13-14 really fast and even when the gauge went to 10.0 the data logs are somewhat just stuck bouncing between 13-14 afr
Post your calibration as well as a datalog showing the issue.
AndrewJ
Post by AndrewJ »
Spunkster wrote: Thu Aug 20, 2020 4:37 pm Post your calibration as well as a datalog showing the issue.
So as i was looking under the dash the the blue wire was connected to the ecu instead of the white wire so i am going to rewire the wideband to the ecu and re test it to see if the problem goes away
AndrewJ
Post by AndrewJ »
Fixed the problem it was the wiring after all this car was wired 3 years ago following aem’s instructions using the blue wire and after reading you have to use the white for the computer to read it properly
