Ep3 k20a2 PRA ecu loss power before and after mapping
Re: Ep3 k20a2 PRA ecu loss power before and after mapping
based on the strange wires added to your ECUI would recommend that you try your ECU in a known working vehicle. If it still does not work correctly, then you should replace your ECU.
jswett1996
Post by jswett1996 »
Hey There first post. How come in the second datalog you have an idle of almost 1500 vs in the first around 800-900? I also noticed looking at the datalog that was first uploaded the 02 Sensor voltage is acting different and not responding in the same manner. It could be you just had a bad o2 sensor? thanks.
