P1607 ecu internal malfunction
Re: P1607 ecu internal malfunction
Once you use the K-Pro you cannot remove the K-Pro. Since the ECU has been damaged it cannot be used.
elijen
Post by elijen »
uf no good :(
can i reuse this kpro in other ecu?
Yes the dealer that did the installation should be able to install it in a working ECU.
elijen
Post by elijen »
ok, thank you very much for the info and your time to help me
