CPR Tach light goes off and car shuts down
Re: CPR Tach light goes off and car shuts down
What MAP sensor are you using?
white2015
Post by white2015 »
I am using the hondata 4 bar. It is rather old, probably 7 years old. I wasn't sure if it malfunctioned, would it default to the max voltage or if maybe the wiring itself is bad. But i couldn't find any wiring issues when i looked at it. Thanks!
You may want to try with the stock map sensor and see if that works, as you can see the MAP sensor is spiking with no input to cause it.
white2015
Post by white2015 »
Yeah. I don't have a stock sensor, so i ordered another 4 bar and will give it a try. Thanks for the help!
LORDWD40
Post by LORDWD40 »
Sorry to jump on a old post but did you sort out the problem?
Thank you
