02 civic si tune help?
Bbert209
Re: 02 civic si tune help?
Post by Bbert209 »
Bbert209
Post by Bbert209 »
Its the one im using
CalibratEd
Post by CalibratEd »
I reviewed the files and it seems to have a good amount of knock and the fuel can use fixing. Do you plan on staying 87 octane fuel? It will take a few revision to get the tune straighten out.
-Ed
Instagram: calibrated.tuning
Bbert209
Post by Bbert209 »
Do you recommend me going to 91?, I was running the 87 cause as is it doesn't gain anything from 91, but I can switch if you want me too, its no biggie.
CalibratEd
91 would allow us to run more timing but seeing as its a stock K20a3 there will not be much gain. Attached is a base tune. Load it on your car and log the car normal driving for 10-15 minutes. We will be addressing part throttle first.
-Ed
Bbert209
Post by Bbert209 »
Ok ill head out now, I have like almost 3/4 of half a tank, ill fill the rest with 91 so it might be dodgy for a bit
Bbert209
Post by Bbert209 »
8min.kdl
13min.kdl
last.kdl
CalibratEd
I did a few adjustments. Load the file and create another normal driving datalog.
-Ed
Bbert209
Post by Bbert209 »
7min.kdl
14min.kdl
final.kdl
CalibratEd
I am working on dialing in the part throttle. The cam angle is locked to 0 so the car might not feel as nimble but no worries its part of the process. We have to tune each cam angle. Load this file and datalog normal driving. We are not to into the tune so its ok if you are switching fuels.
-Ed
Bbert209
Post by Bbert209 »
Ok, ill head out in a bit, thank you.
Bbert209
Post by Bbert209 »
7min.kdl
14min.kdl
final.kdl
CalibratEd
Make sure you loaded Rev2. The car is crossing into Vtec and the Cam angle is being changed.Also double check if you uploaded the wrong datalogs.
-Ed
Bbert209
Post by Bbert209 »
Im prety sure i did but ill do it again in the morning
Bbert209
Post by Bbert209 »
7min.kdl
14min.kdl
final.kdl
