Cool thanks! Alright let me try it out. Should I stop-n-go traffic? WOT perhaps?CalibratEd wrote: Wed Jun 30, 2021 7:43 pm Load the tune and datalog the car normal driving. I smoothed out the map to have a base to work with.
-Ed
Requesting a B20V basemap
anonymous408
Re: Requesting a B20V basemap
- CalibratEd
- Contact:
Stop and go driving for now. I want to asses how the fueling is doing.anonymous408 wrote: Thu Jul 01, 2021 11:13 amCool thanks! Alright let me try it out. Should I stop-n-go traffic? WOT perhaps?CalibratEd wrote: Wed Jun 30, 2021 7:43 pm Load the tune and datalog the car normal driving. I smoothed out the map to have a base to work with.
-Ed
-Ed
Instagram: calibrated.tuning
anonymous408
I tried it out just now. I had to adjust the IAC to get it up for the first time. Initially it wouldnt continue to run once I started it. Then I removed the FPR vacuum line then started again and it idled fine. After idle is fine I plugged the vacuum hose back in and went for a drive.
After shifting gears and about to come to a stop I press in the clutch then it died out. Only way to start it up is to press on the gas a little to give it more air and off I go.
You can check out the datalog file here. Thanks for looking into it!
anonymous408
Oh and AFR does go from 15ish to around 14.7, hiccup here and there but it managed to come down between those two numbers.anonymous408 wrote: Thu Jul 01, 2021 12:57 pm I tried it out just now. I had to adjust the IAC to get it up for the first time. Initially it wouldnt continue to run once I started it. Then I removed the FPR vacuum line then started again and it idled fine. After idle is fine I plugged the vacuum hose back in and went for a drive.
- CalibratEd
- Contact:
I am cleaning up the fuel so it might run a little sluggish for now. Load the new tune and create another normal driving log. Try to get higher in the RPM with out going WOT.
-Ed
-Ed
anonymous408
It feels more sluggish. Died on the road couple of times when clutch was pressed in. Runs 17sh AFR. Heres what I have for the datalog.CalibratEd wrote: Thu Jul 01, 2021 7:24 pm I am cleaning up the fuel so it might run a little sluggish for now. Load the new tune and create another normal driving log. Try to get higher in the RPM with out going WOT.
-Ed
anonymous408
Okay I tried to fix the idle stop screw and now its idling at around 14ish, not the previous 17sh I mentioned. Too late to test drive it now but I will tomorrow. I just hope I dont die again lol.anonymous408 wrote: Thu Jul 01, 2021 9:18 pmIt feels more sluggish. Died on the road couple of times when clutch was pressed in. Runs 17sh AFR. Heres what I have for the datalog.CalibratEd wrote: Thu Jul 01, 2021 7:24 pm I am cleaning up the fuel so it might run a little sluggish for now. Load the new tune and create another normal driving log. Try to get higher in the RPM with out going WOT.
-Ed
- CalibratEd
- Contact:
I added a lot more fuel to this revision. I will trim the fuel out once we make sure the car is not leaning out on you.
-Ed
-Ed
