Target Lambda Tables
Re: Target Lambda Tables
This can be done in the closed loop section of the parameters window.
futureal33
Post by futureal33 »
PLease can you be really basic and literally tell me which button to click, I am in closed loop parameters and cannot see anything that says enable closed loop.. Please help
futureal33
Thanks for the link but thats not really answering my question
My closed loop parameters is set up using the wideband however as per my original post, it is running in open loop all the time
TTR
Post by TTR »
uncheck disabled (open loop) at the top. That will put it in closed loop using whatever method is also selected (built in or external).
futureal33
Thats the problem, it's already not disabled... (the stock wideband is selected) but the whole log is fuel status 4 open loop
Post your calibration and a datalog showing the issue.
futureal33
I posted them on another thread as I didnt want to take over the original poster's question, but I've put them below here
2003 DC5 JDM running the K20a-ITR basemap
I believe you were told not to use that calibration and to use a different one instead.
