In need of basemap please
Re: In need of basemap please
UPDATE: I fixed the red blinking led on my ECU situation. I had a broken ground wire in my harness that led to the valve cover.
Everytime I start my car it will crank and turn over but will die IMMEDIATELY.
I had the TPS and MAP sensor backwards and it ran but it was really rough. I corrected the plugs and it will crank and turn over but die immediately. I’m running a stock MAP that I obtained with my kpro from hondata and I described my build to them. Still no luck.
Any help?
Any help?
- CalibratEd
- Contact:
Is the car throwing any codes? Did you disable the immobilizer?Can you keep the car on by pressing the gas pedal? Are you using the same Calibration file as before?DC5_Jess wrote: Sun Jul 11, 2021 3:15 pm UPDATE: I fixed the red blinking led on my ECU situation. I had a broken ground wire in my harness that led to the valve cover.
Any help?
-Ed
Instagram: calibrated.tuning
The car isn’t throwing any codes.
The car can be kept running if I give it gas.
Immobilizer has been shut off.
This is the same tune as I ran before.
I thought the 70mm throttle body was throwing the A/F off too much so I installed my stock 62mm back on and still have the same problem.
- CalibratEd
- Contact:
Can you datalog the car? Keep it on until it reaches operating temperature. I want to see what the AFR is. It sounds like more like a mechanical or electrical issue.DC5_Jess wrote: Mon Jul 12, 2021 5:29 am The car isn’t throwing any codes.
-Ed
I GOT IT RUNNING! YAY! Thank you everyone that helped
Now I just need someone to bless me with a tune so I can get it running right.
I datalogged a 32 minute idle with a few revs up to about 4k for a start, I will link it to this post.
I am no longer running a 70mm Throttle body. I am back to stock 62mm Type S (K20A2) throttle body
Not to sound annoying, I just want to be clear because that throttle body was giving me nothing but trouble.
My datalog is too big of a file so I uploaded it to MediaFire.
Here's the link: https://www.mediafire.com/file/sd8y1g4y ... g.kdl/file
I appreciate any and all help guy, THANKS!
- CalibratEd
- Contact:
That is great to hear. So the throttle body was the issue? I can help tune the car not that you have it running.DC5_Jess wrote: Wed Jul 14, 2021 7:05 pm I GOT IT RUNNING! YAY! Thank you everyone that helped
-Ed
The Throttle body was part of the issue. It wasn’t fitting my MAP sensor correctly so the car wouldn’t stay idling. I also needed a new MAP because it got fried from me swapping the MAP and TPS plugs.
All figured out now, thank you for the support!
I just need some help with the base map and then I can bring it to get dyno tuned, I just need it to be able to drive there.
Thank you
Thank you
- CalibratEd
- Contact:
Sounds good. Does the car now idle without pressing the throttle?DC5_Jess wrote: Fri Jul 16, 2021 8:07 am The Throttle body was part of the issue. It wasn’t fitting my MAP sensor correctly so the car wouldn’t stay idling. I also needed a new MAP because it got fried from me swapping the MAP and TPS plugs.
Thank you
-Ed
Yeah. In my datalog I attached to my last post it was at idle for majority of it. I only rev’d it a few times at the end.
- CalibratEd
- Contact:
Load the base tune and datalog it normal driving.
-Ed
-Ed
Hello, Sorry for the large gap in responses. I had a lot of this to troubleshoot, this being my very first K series build there was definitely a learning curve coming from a 350 Small Block Chevy.
I have solved all my issues and am almost ready to road test it. I just need to replace my VTEC Solenoid Gasket due to it leaking oil and I need to buy some tires due to two flat tires. I'm hoping to road test it before first snowfall. If I do then I'll post my datalog on here the day of.
I appreciate all of the help from this forum and it's great community.
Thank you,
DC5_Jess
Thank you,
DC5_Jess
Sorry to resurrect an old thread.
I recently was able to road test my RSX and I noticed when I try to floor it the car falls on its face.
I datalogged it while i took it for a few laps around the block.
I was hoping anyone would be able to diagnose it for me. Any help is appreciated
- CalibratEd
- Contact:
Replied to your PmDC5_Jess wrote: Mon Mar 14, 2022 5:08 pm Sorry to resurrect an old thread.
First Road Test 37 mins.rar
