What basemap should I use ?
kj6564
Re: What basemap should I use ?
Post by kj6564 »
Do I add as the secondary tune or delete the first one and add it as the first?
kj6564
Post by kj6564 »
This is the second datalog. I did a couple pulls. Hopefully it should be good.
EFICU
Post by EFICU »
Sorry just saw your other post, I would just keep copying over the first one until we get the final version. Then you can make it the main calibration in the FP.
That one looked great. I made a some idle fuel adjustments, and a few WOT fuel adjustments. The part throttle trims were great, and the knock is gone. We might be there on this next, if not we're really close.
Same datalog and driving style, that one had a lot of good data. If you want to have more fun with it you can, it's 99.9% there, so feel free to drive it however you want. Just be sure to get at least one clean third gear pull.
KJ6564.SD.Rev03 (Vtec4300).fpcal
kj6564
Post by kj6564 »
Sounds good , I will have the data log tomorrow, it felt great as well.
kj6564
Post by kj6564 »
I recorded a datalog but its telling me the file is too large. I did the datalog for like 32-33 minutes which is probably why correct?
CalibratEd
Post by CalibratEd »
kj6564 wrote: Fri Aug 13, 2021 7:04 pm I recorded a datalog but its telling me the file is too large. I did the datalog for like 32-33 minutes which is probably why correct?
Yes the size is to large to upload.
Open the datalog in Flashpro Manager, on the timeline Left click about 15-20 minutes into the datalog then right click and select "set new end". Save it with a new file name and upload it.
Repeat the step above with the original file but this time when you reach the 15-20 minute mark you select “set new beginning”. This way you get the second half of the log.
I have also seen people zip the file and upload it.
EFICU,
I hope I am not stepping on any toes. Didn’t want any downtime on getting the datalog to you.
-Ed
Instagram: calibrated.tuning
kj6564
Post by kj6564 »
Will try it, Thank you very much for the info !
EFICU
Post by EFICU »
No problem Ed.
Kj, my email is under the “calibration” tab of the files I send you. You can email it to me as well if needed. If you do trim the datalog as Ed outlines, try to get the WOT pull in there please. If you have any questions, let me know.
kj6564
Post by kj6564 »
Here is the datalog for today. I did 2 3rd gear pulls. Hopefully everything is well. Sorry for uploading so late, was really hot today and figured it would be better to datalog in cooler temperatures.
EFICU
Post by EFICU »
No problem, and yeah tuning in the same weather is ideal so that is nice. Only so you're comparing apples to apples with similar or no comps.
That one looked good, needed a couple little changes, and some ignition for a knock that showed up. Super close though, just nitpicking things at this point. Take this one for a spin when you can, same datalog and driving style.
KJ6564.SD.Rev04 (Vtec4300).fpcal
kj6564
Post by kj6564 »
Sounds great will have it tomorrow morning. Thanks!
kj6564
Post by kj6564 »
Here is the second datalog, Did 2 3rd gear pulls as well. Hopefully its good, Thanks!
EFICU
Post by EFICU »
Had some new knock pop up, it all happened in a group of like 6 cells in the part throttle driving. Which is good, because it means just that one area is sensitive. So I removed some timing in that area to get rid of it. Part throttle fueling is great, WOT fueling was really close, I made a couple 1% changes here and there.
Give this next one a drive and we'll see how it looks. Sorry for dragging this out for you, just trying to get it all dialed perfect.
KJ6564.SD.Rev05 (Vtec4300).fpcal
kj6564
Post by kj6564 »
Here is the datalog for today, The 3rd gear pull is near the end. Sorry for uploading late just got busy with some stuff, hopefully it turns out good. Thanks!
EFICU
Post by EFICU »
Little bit of knock in the same area. Made some more adjustments, and a couple small fuel adjustments. This one should be there. We'll see how it looks.
