S2000 Kpro Low/High Boost
AngryScottish
Re: S2000 Kpro Low/High Boost
Post by AngryScottish »
Spunkster wrote: Mon Oct 25, 2021 9:48 am What is the serial umber on the K-Pro board inside the ECU?
Not sure which one you needed, so took a photo and attached.
But, it's a PPA ECU:
37820-PPA-A07
That is not the serial number on the K-Pro board.
AngryScottish
Spunkster wrote: Mon Nov 01, 2021 10:50 am That is not the serial number on the K-Pro board.
My bad, you did say kpro board.
47206.
This ECU has not been prepared for use in an S2000, and a PPA ECU is not supported for use with the S2000.
AngryScottish
Spunkster wrote: Tue Nov 02, 2021 9:24 am This ECU has not been prepared for use in an S2000, and a PPA ECU is not supported for use with the S2000.
This is unrelated to a S2000. I am just posting in the thread because of the low/high boost issue that the OP was discussing.
I recommend you start your own thread so there is no confusion then.
