2012 Si base map tune
Re: 2012 Si base map tune
I had time to do a run this morning. Check it out when you get a chance.
Yeah it looks really good. So I've gone in and blended out all the tables, so take this one for a spin and see what you think. Vtec looks happiest at 4300, so we'll see how that works in this one and how it feels in the car. Shoot for twenty minutes on the datalog with at least one third gear pull, but feel free to drive it however you want. Feel free to have some fun with it if you want.
Here is a 20 minute run blended. Check it when you have a chance.
It looks really good. I made a couple small WOT fuel adjustments, and some ignition adjustments for the knock. Take this one for a spin when you can. No rush, it's 99% there.
Hi there I came across this post. I’m kinda running into the same problem. Basically I have kinda the the same mods on my 12 si. And I’ve been noticing that my knock has been going up specifically when I push it abit. I was wondering is this tune could work on my application too thanx.EFICU wrote: Wed Apr 27, 2022 9:23 pm It looks really good. I made a couple small WOT fuel adjustments, and some ignition adjustments for the knock. Take this one for a spin when you can. No rush, it's 99% there.
SDblaze66.SD.Rev07 (Blended)(Vtec4300).fpcal
Currently using this tune on my 13 Si. No problems so far. Good luck 🤙Rene09 wrote: Thu Jul 30, 2026 4:08 pmHi there I came across this post. I’m kinda running into the same problem. Basically I have kinda the the same mods on my 12 si. And I’ve been noticing that my knock has been going up specifically when I push it abit. I was wondering is this tune could work on my application too thanx.EFICU wrote: Wed Apr 27, 2022 9:23 pm It looks really good. I made a couple small WOT fuel adjustments, and some ignition adjustments for the knock. Take this one for a spin when you can. No rush, it's 99% there.
