Page 2 of 5
Re: Skunk2 CAI and FlashPro
Posted: Wed Apr 13, 2022 11:22 am
by Joshua97
Took the car for a drive with the new calibration you gave me. Here's the datalog from said drive. Thanks!
datalog0004.fpdl
Posted: Wed Apr 13, 2022 3:42 pm
by EFICU
It looks pretty good. I made some adjustments, we'll see how this one looks. Take it for a spin when you can.
Joshua97.SD.Rev03 (Blended)(Vtec4500).fpcal
Posted: Wed Apr 13, 2022 7:28 pm
by Joshua97
Here's a datalog with the new calibration. Thanks!
datalog0008.fpdl
Posted: Wed Apr 13, 2022 8:29 pm
by EFICU
Did the car feel faster in the very first calibration, or does it feel pretty much the same in the most recent revision?
Posted: Wed Apr 13, 2022 8:40 pm
by Joshua97
It felt a lot faster in the first calibration especially during the 3rd gear pull.
Posted: Wed Apr 13, 2022 8:57 pm
by EFICU
Kinda got that vibe watching the tack in the datalogs, that's interesting because I didn't change much to cause it to do that. I went back to the first calibration here and made some different adjustments than how I did it the first time around. Take this one for a spin like you have been, and see if third feels strong again. It should, but let me know, then we'll go from there.
Joshua97.SD.Rev01.1 (Blended)(Vtec4500).fpcal
Posted: Thu Apr 14, 2022 9:24 pm
by Joshua97
Sorry for the late reply I was at work all day. Third feels strong again so whatever was changed worked. I did notice my launch control is no longer active though. Was that a setting you changed for a reason? Just curious, Here's the datalog from the calibration you sent. Thanks!
datalog0011.fpdl
Posted: Thu Apr 14, 2022 9:58 pm
by EFICU
No problem, yeah that one looked a lot better. And no, I didn't change anything to do with the launch control, it's set at 5000 in the file, but you can change it through the steering controls to test different rpms if you want. Try it again in this calibration and we'll see if it's working, be sure the clutch pedal is all the way to the floor as well.
Anyways, take this one for a spin when you can. It only needed a few small adjustments so that's good. We'll see how this next one looks.
Joshua97.SD.Rev04 (Blended)(Vtec4500).fpcal
Posted: Fri Apr 15, 2022 9:05 pm
by Joshua97
Oh ok I didn't realize it was set at 5000 my bad. I was used to it being at stock RPM. I took the datalog for this etune and have them attached for you below. Thanks!
datalog0013.fpdl
Posted: Fri Apr 15, 2022 9:43 pm
by EFICU
It looks really good. No knock, and the WOT fuel and part throttle fueling look good. Go ahead and make another datalog this weekend sometime, and we'll see how it looks. We're definitely on the right track now.
Posted: Mon Apr 18, 2022 11:04 pm
by Joshua97
Hey sorry I didn't post a datalog yesterday I was busy with family. I have a datalog for you to look at. I do have a slight issue I started noticing yesterday though. Under throttle in 3rd to 6th gear at about 3000 to 4000 RPM the engine will suddenly lose power for half a second tops and causes the car to jerk. It's very random but I was able to capture it once in the datalog I've attached. It's near the beginning of the log, around 5 to 10 minutes in. Is there any way you could look at that and see if something's going on? I would appreciate it immensely.
datalog0014.fpdl
Posted: Tue Apr 19, 2022 10:33 am
by EFICU
Overall it looks great. Can you be a little more specific at the time of the issue you mention? There is a lot to look at it a five minute range you mention, and even then the issue might not be obvious. I have a theory, but it would be better if I can see the issue in the timestamp to investigate it better. Let me know
Posted: Tue Apr 19, 2022 2:11 pm
by Joshua97
Honestly I don't remember exactly when it happened. However, I went out today to try and replicate it again today to give you a better time frame. In the datalog I have attached the issue happens in the last 15 seconds or so of the datalog. I hope that is a lot better of a timeframe for you. If not I can go out again and try and be more precise. Thanks!
datalog0016.fpdl
Posted: Tue Apr 19, 2022 8:55 pm
by EFICU
Yeah I see what you mean, although it's a little strange, and not what I thought it might be. I made a small change to this next file, give this one a drive and see if you can recreate the issue.
Joshua97.SD.Rev04.1 (Blended)(Vtec4500).fpcal
Posted: Wed Apr 20, 2022 12:16 pm
by Joshua97
What did you think it might be? Were you able to see what was causing the issue in the datalog I sent to you? I'm going to give it a test drive now. I'll let you know how it goes! Thanks!
