Can anyone help me setup a base map for my kswap Lotus?
saxon_schmauderer
- CalibratEd
- Contact:
Re: Can anyone help me setup a base map for my kswap Lotus?
Instagram: calibrated.tuning
- CalibratEd
- Contact:
Saxon,
Load the base file and datalog the car at idle and then a normal driving log if possible. You mentioned you are running the OEM wideband. Do you plan on installing an aftermarket widenband?
-Ed
-Ed
saxon_schmauderer
I have the factory RSX Upstream sensor on the car right now. Do you think there would be a big benefit to going with a aftermarket wideband? If so, I can order one now before grabbing logs. Is there a specific wide-band that plays well with the Hondata ECU? Forgive me for my ignorance, I am new to the Honda scene.
saxon_schmauderer
It appears I DID buy a wideband for the car. I bought the following o2 sensor:
https://www.hybrid-racing.com/products/ ... ies-engine
- CalibratEd
- Contact:
I highly recommend anyone running a forced induction setup to install an aftermarket wideband. Popular ones are AEM, Innovate and PLX.
They all work well with Hondata.
-Ed
-Ed
saxon_schmauderer
Roger, I will order one. In the meantime I will run what you sent and send you the logs. Thanks!
- CalibratEd
- Contact:
Sounds good.saxon_schmauderer wrote: Mon May 09, 2022 11:06 am Roger, I will order one. In the meantime I will run what you sent and send you the logs. Thanks!
-Ed
saxon_schmauderer
OK I have the car up and running well enough to drive it around a bit. For the data log are you looking for anything in particular? How much driving do you need etc? I wanted to make sure that you have what you need in order to progress with the next step.
- CalibratEd
- Contact:
If the car is idling well. I just need a normal driving datalog to dial in the part throttle. Let’s say. 5-15 minutes drive.
- Ed
- Ed
saxon_schmauderer
I wouldn't say it is idling well*. It seems to be kind-of surging. I am assuming that is due to the bad AFR readings it is getting (It is actually running very rich), but the AFR's are very high. I am attributing that to bad placement of the wide band sensor so I am going to re-locate that tonight before confirming.
I set the idle a bit higher - in the tune (And the drive by cable throttle) to about 1000rpm and it idles much better.
I noticed you set the boost cut to 5psi. Can I move that up a bit so I can drive in the higher RPM range? I have a 14psi spring in the wastegate so in order to fully rev the car out i would need to raise it to at least 15psi.
thanks,
-Saxon
thanks,
-Saxon
saxon_schmauderer
Also it dies immediately after starting if I don't give it little gas (If I didn't raise the idle to 1000rpm). Once I give it a little throttle I can immediately let off and it stays running.
- CalibratEd
- Contact:
I would avoid going into boost i till we have dialed in the part throttle.saxon_schmauderer wrote: Mon Jun 06, 2022 2:16 pm I wouldn't say it is idling well*. It seems to be kind-of surging. I am assuming that is due to the bad AFR readings it is getting (It is actually running very rich), but the AFR's are very high. I am attributing that to bad placement of the wide band sensor so I am going to re-locate that tonight before confirming.
thanks,
-Saxon
-Ed
- CalibratEd
- Contact:
Create a datalog of the car at idle after it has reached operating temperature. Then create a datalog of Normal driving. I’m sure it need some fuel adjustments.saxon_schmauderer wrote: Mon Jun 06, 2022 2:18 pm Also it dies immediately after starting if I don't give it little gas (If I didn't raise the idle to 1000rpm). Once I give it a little throttle I can immediately let off and it stays running.
-Ed
saxon_schmauderer
When the car is idle, (at 1000rpms), it actually sounds very healthy, BUT the AFR values sit very high as you can see in the data log I attached. Once I give the car throttle and get into the higher RPM range the AFRs come way down to a safe 14ish. I am still using the Factory RSX Wide Band sensor, but I still didnt think this would be an issue. I did test out a different MAP sensor offset value jus to see if it would change anything and it did indeed make the AFR's sit at around the desired 14 when idle. I dont know if that helps at all. Just spit balling ideas.
