K24a2 swapped ep3 tune assist
Burgturdler
Re: K24a2 swapped ep3 tune assist
Post by Burgturdler »
Saw a little more knockcount. Just letting you know its pretty hot and I had the AC on. I was able to fit my old exhaust with a high-flow cat as well. In case anything looks off.
CalibratEd
Post by CalibratEd »
I reduced the timing where knock was present. Load the new file and create a normal driving datalog with 3 WOT pulls.
-Ed
Instagram: calibrated.tuning
Burgturdler
No knock events in the pulls. The three present very early on are in slow traffic.
CalibratEd
We are moving to VTC 30. Create a normal driving log. Once I confirm fuel is fine we can move to WOT. I noticed the car knocked in the last datalog due to you reving it to high. You should not rev the car past 7400. You rev'd the car up to 8300. I move up the rev limit so that the car doen't cut fuel.
-Ed
Burgturdler
Updated log. Sorry, I wasn't paying attention to the RPM range as I was in the 7400 range at about 80mph so thats all I was looking at for the last log. I'll make sure to watch RPMs to be sure.
CalibratEd
Create a normal driving log with a 3 WOT pulls.
-Ed
Burgturdler
New logs. Idle felt funny initially, i checked for vacuum leaks or loose hose but didn't see any. Seemed to smooth out during the drive.
CalibratEd
Cleaned up some of the fuel. Create a normal driving log with a WOT Pull. If all is well we will move to VTC 40.
-Ed
Burgturdler
For your review. Thanks.
CalibratEd
Create a normal driving log with a few wot pulls.
-Ed
Burgturdler
Far less knock events. 5th gear moving in traffic feels much better with the latest revisions.I could only do 2 full WOT pulls. Last one was cut short. Thanks.
CalibratEd
Finishing up the non Vtec side and blending the VTC tables. Create a normal driving log with a WOT Pull.
-Ed
Burgturdler
Completed. Thanks.
CalibratEd
Moving to the Vtec side VTC 0. Create a normal driving log.
-Ed
Burgturdler
Sorry this log ended up being a little longer than normal. I ran into a ton of traffic and couldnt get to my computer to restart the log.
