My Knock control keeps rising on every pull
Re: My Knock control keeps rising on every pull
Try going back to the 9pis calibration and in the mods check the one for artificial knock disable and see if that has any effect.
destinray26
Post by destinray26 »
Spunkster wrote: Wed Jun 15, 2022 12:55 pm Try going back to the 9pis calibration and in the mods check the one for artificial knock disable and see if that has any effect.
i already had that checked, i did that on the +6 psi as well. also disabled VSA and misfire detection
IT was not checked in the 9psi calibration you uploaded
destinray26
Spunkster wrote: Wed Jun 15, 2022 1:15 pm IT was not checked in the 9psi calibration you uploaded
Okay I’ll do that right now
destinray26
okay so i disabled the artificial knock at WOT and it still is having an issue
You should probably look into getting tuned on the dyno, or having an e-tuner work on the calibration for you.
destinray26
Something is wrong!
I need someone to help me out with the calibration I’m running. Keeps getting 70 knock control and I’ve already turned off disable artificial knock at WOT. Doesn’t do this on the stock calibration so if anyone can help it would be much appreciated I can send some money for the trouble too!
