Rev Limiter activating between 3500-4000 rpm
Re: Rev Limiter activating between 3500-4000 rpm
I would recommend that you replace the capacitors in the ECU: https://www.hondata.com/products/access ... acitor-kit
irontable1_
Post by irontable1_ »
I’ve got another P28 with new capacitors on order. I’ll replace the ones in the Ecu I have now. Hope it works. I appreciate your help on this one. I’ve been losing sleep. Thank you very much!!
Did the plugs I showed you check out or should I change to the ones that are on the hondata website?
P.S This is not a CPR setup. Stock distributor if that matters.
That part number should be ok for plugs as they are resistor type.
