K24 frank Etune help
CalibratEd
Re: K24 frank Etune help
Post by CalibratEd »
Cleaned it up a bit more. Create normal driving log with a WOT pull make sure to monitor the AFR.
-Ed
Instagram: calibrated.tuning
RippinDC2
Post by RippinDC2 »
Normal driving with a 3rd gear WOT pull. I tried to keep an eye on AFR's best I could, it did lean out up top.(oops) Idle surging slightly at the end of the log. Overall driving very nice at part throttle.
download/file.php?mode=view&id=18863
CalibratEd
Cleaned up fuel and timing. Create a normal driving log with a WOT pull. During WOT rev up to 7500. I move the limiter so the car doesn't bounce off the limiter.
-Ed
RippinDC2
Post by RippinDC2 »
New log for you. So far, so good! Drives better every time you make an adjustment!
download/file.php?mode=view&id=18867
CalibratEd
Moving to VTC 10. Create a normal driving log.
-Ed
RippinDC2
Post by RippinDC2 »
Getting a little bit of knock around 3000 rpms cruising. New log attached
download/file.php?mode=view&id=18873
CalibratEd
Cleaned up fuel and removed timing in knock areas. Create a normal driving log with a wot pull.
-Ed
RippinDC2
Post by RippinDC2 »
The car felt like it was easier to shift, a lot smoother.
download/file.php?mode=view&id=18876
CalibratEd
Cleaned up more fuel and timing. create a normal driving log with a WOT pull.
-Ed
RippinDC2
Post by RippinDC2 »
Definitely smoother, had some knock in 6th gear low rpms. I was lugging it a little bit.
download/file.php?mode=view&id=18892
CalibratEd
Cleaned up the fuel. I am monitoring the knock as I believe it may be false knock due to the camshaft.
-Ed
RippinDC2
Post by RippinDC2 »
I think you're right with the false knock. The only knock I'm actually hearing is when I first go WOT. It knocks a couple times and that's it. Also noticed some slight bucking at low throttle input on the last run.
download/file.php?mode=view&id=18905
CalibratEd
Cleaned up fuel and timing. Create another normal driving log with a WOT pull.
-Ed
RippinDC2
Post by RippinDC2 »
Sorry about the delay, its been raining every day here. New log attached!
download/file.php?mode=view&id=19002
RippinDC2
Post by RippinDC2 »
Please disregard my last log. The throttle body was just about falling off the car. I'll fix the issue and post a new log.
