MAP Channel stuck
terrorista
Re: MAP Channel stuck
Post by terrorista »
Spunkster wrote: Fri Apr 26, 2024 12:29 pm What wiring has been modified in the vehicle?
Adding some extra Data .. From the last car happening.
Please check the datalog .. First 10 sec the map is stuck. We took ou the connector, plug it again.. Re-fire the engine .. And the reading back to OK.
calibration is locked
terrorista
Spunkster wrote: Fri Apr 26, 2024 12:58 pm calibration is locked
My Bad ... Attached Unlocked ...
How exactly are the boost control and wideband wired.
terrorista
Spunkster wrote: Fri Apr 26, 2024 1:18 pm How exactly are the boost control and wideband wired.
WBO with Analog channel direct to pin ...
BC have a fuse before entering B2, other terminal have a tic-tac switch to turn boost on and off aside the VSA switch, the ground used for it is from the body.
If these are all removed, does the same issue persist?
terrorista
Let me try that ...
The only strange thing is that this "lock" happens in other cars too.
terrorista
Spunkster wrote: Fri Apr 26, 2024 1:38 pm If these are all removed, does the same issue persist?
Just Removed the wires ... Same Issue ... Just happens with 4bar map sensors. With OEM Map .. Nothing happens.
Attached the starting datalog wth cut wires.
terrorista
What else can we test spunkster? Thanks
I tested this in our 06 Si and it reads the 4bar as it should. I suspect there is some other cause on these vehicles.
