J_Lovell2007
Posts: 16 Joined: Sat May 13, 2023 3:28 pm
Post
by J_Lovell2007 » Fri May 19, 2023 4:48 pm
datalog0003.fpdl
datalog0002.fpdl
datalog0001.fpdl
datalog0000.fpdl
CalibratEd
Posts: 1714 Joined: Fri Feb 07, 2020 3:20 pm
Post
by CalibratEd » Sat May 20, 2023 7:37 pm
Yes, the logs were good. The calibration needs fuel adjustments. It is running lean. Timing is ok as there is no knock present.
-Ed
Instagram: calibrated.tuning
J_Lovell2007
Post
by J_Lovell2007 » Sun May 21, 2023 12:11 pm
Thanks for looking into that Ed! One last question should I stay away from high RPM's just drive it normal until I get fuel adjusted?
CalibratEd
Post
by CalibratEd » Sun May 21, 2023 12:18 pm
J_Lovell2007 wrote: Sun May 21, 2023 12:11 pm
Yes, don’t drive the car too hard until you have the fuel dialed in. It’s better to play it safe. Once you make the corrections post the logs and I can let you know if you’re on the right track.
-Ed
J_Lovell2007
Post
by J_Lovell2007 » Sun May 21, 2023 12:20 pm
Thanks Ed! I'll keep you updated thanks for the advice.
CalibratEd
Post
by CalibratEd » Sun May 21, 2023 12:32 pm
J_Lovell2007 wrote: Sun May 21, 2023 12:20 pm
No problem.
-Ed
J_Lovell2007
Post
by J_Lovell2007 » Tue May 23, 2023 2:13 pm
Hey Ed got a tune today, check it out see what you think? I can send more data over if you need thanks!
-Justin
CalibratEd
Post
by CalibratEd » Thu May 25, 2023 2:09 pm
J_Lovell2007 wrote: Tue May 23, 2023 2:13 pm
-Justin
Post the calibration file from your tuner so i can review the logs.
- Ed
J_Lovell2007
Post
by J_Lovell2007 » Thu May 25, 2023 5:51 pm
CalibratEd
Post
by CalibratEd » Thu May 25, 2023 8:10 pm
Fuel doesn't look bad and there is no knock. I can't dig deeper because your tuner locked the file. I am not a fan of locked tunes. I never lock customer tunes.
-Ed
