K24a2 with k20z4 head
MURPHITOJONES69
Re: K24a2 with k20z4 head
Post by MURPHITOJONES69 »
The surging idle sir
CalibratEd
Post by CalibratEd »
Not if its a mechanical issue.
-Ed
Instagram: calibrated.tuning
MURPHITOJONES69
Interesting, what would you suggest I do next?
CalibratEd
Diagnosis the car. Check if the car is throwing any codes. Check for vacuum leaks.
-Ed
MURPHITOJONES69
I will get on it as quick as I can. I'll let you know what I find
CalibratEd
MURPHITOJONES69 wrote: Wed Jul 26, 2023 1:59 pm I will get on it as quick as I can. I'll let you know what I find
Sounds good.
-Ed
MURPHITOJONES69
Hi, will throttle body cleaner work as a spray to check for vacuum leaks and if so I found no vacuum leaks while spraying. Also my no error codes came up
CalibratEd
I saw in your previous post that you cleared the code. The IACV might be your issue. The code might come back. Try setting the tune to not use the IACV and see what happens.
-Ed
MURPHITOJONES69
I've tried setting the tune to disable the iacv last night. Also it's a new oem iacv from factory. I appreciate the help
CalibratEd
MURPHITOJONES69 wrote: Thu Jul 27, 2023 7:40 am I've tried setting the tune to disable the iacv last night. Also it's a new oem iacv from factory. I appreciate the help
Try another IACV or block it off as a test.
-Ed
