02 Base W/ K24
shawnjawn17
Re: 02 Base W/ K24
Post by shawnjawn17 »
I am trying to hook up the wideband via ELD 15 wire(which is hooked up) but i cannot find how to do it in Hondata itself. Kpro is a green board , not white board as discussed earlier but no write-ups on setting this in Hondata. I did upload another datalog for you to see after swapping Cam sensors car ran beautiful and i cant thank you enough !! Once i can get wideband reading via Hondata, i will be able to post more accurate logs but wideband is at low 12s/mid 12s at idle
Re: 02 Base W/ K24
The settings are under Options, Settings, Wideband input.
CalibratEd
Re: 02 Base W/ K24
Post by CalibratEd »
Connect the wide band to ELD pin and then follow as Spunkster said. Post a datalog once that's said and done. ELD is already disabled in the tune.
-Ed
Instagram: calibrated.tuning
shawnjawn17
Re: 02 Base W/ K24
Here is log after going into settings like Spunkster said as well as connecting wideband wire to ELD 15 pin on D connector. Fingers crossed i did it correctly.
CalibratEd
Re: 02 Base W/ K24
For the first 30 seconds its reads around 13AFR and then it jumps to 19AFR. The cam sensor also randomly reads 108 for a while. Did the car turn off? Is the wideband reading 19 as well. I want to make sure the data is accurate before I recommend any changes.
-Ed
shawnjawn17
Re: 02 Base W/ K24
No it hasn't done any weird activity at all. Idles go as low as 12.3 and go as high as 13.6 13.7 in afr. I have recorded the wideband gauge itself as well because i figured Hondata could be showing the wrong data as well.
CalibratEd
Re: 02 Base W/ K24
Ok if that’s the case then make sure you don’t have any loose electrical connections and the wideband is properly grounded.
The bright side is the car is running.
-Ed
shawnjawn17
Re: 02 Base W/ K24
Yes and all thanks to you ! I still need to get my speed sensor working properly before going on any kind of test drive. But as far as starting up and idling on its own with decent “afr’s”, I couldn’t have done it without your help Ed! Thank you so much
shawnjawn17
Re: 02 Base W/ K24
Thank you as well Spunkster !
CalibratEd
Re: 02 Base W/ K24
shawnjawn17 wrote: Wed Jul 26, 2023 1:27 pm Yes and all thanks to you ! I still need to get my speed sensor working properly before going on any kind of test drive. But as far as starting up and idling on its own with decent “afr’s”, I couldn’t have done it without your help Ed! Thank you so much
Glad I could help.
-Ed
