K pro won't turn on
Dcuevas913
Re: K pro won't turn on
Post by Dcuevas913 »
Is there a way to check if the board is getting power because even outside of the car the kpro won’t connect to laptop
Did you wire the VSS into the K-Pro board?
Dcuevas913
No I jumped the c101 pin 3 to ecu b11. I have a adapter on vss for css
B11 is not a vss input for the ECU.
Dcuevas913
So did I fry my board? I don’t smell anything or anything like that and my car still starts fine
Dcuevas913
I saw somewhere that it was a input for css conversion
undo whatever wiring changes you made and see if it works as it should. If it does not, you have probably damaged the K-Pro and or the ECU.
Dcuevas913
Okay I did do that and still nothing would I return to who I purchased from or contact hondata directly?
Send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
Dcuevas913
Okay I will do that now
