05/06 RSX with k20a2
Kreetoes
Re: 05/06 RSX with k20a2
Post by Kreetoes »
Would I have to revert back to the A3 engine harness or would the car work with the A2 harness?
The original engine harness should be used in the vehicle.
Kreetoes
Post by Kreetoes »
So I got the ecu re-modified and am currently still only getting a crank.
Will it run on the original ECU?
Kreetoes
Post by Kreetoes »
Yes, it runs on the original ecu
Post the calibration you are uploading to the ECU.
Kreetoes
Post by Kreetoes »
Here is the calibration as well as the datalog when i try to start it
You need to try the K-Pro ECU on a known working vehicle. To see if the ECU starts normally in that vehicle.
Kreetoes
Post by Kreetoes »
I tried the K-Pro in another vehicle and that car has started
It is most likely a problem with the wiring in your vehicle.
