CPR Worked fine, now ignition issue
ruinedxjake
Re: CPR Worked fine, now ignition issue
Post by ruinedxjake »
Looks like this chip in the CPR kit is burnt.
Will it run on just the new distributor without the CPR?
ruinedxjake
Spunkster wrote: Tue Jun 25, 2024 8:52 am Will it run on just the new distributor without the CPR?
I have yet to verify because it would require reversing the wiring and haven't had the time to undo an installation. I am looking at warrantying through the website I bought it through though.
You need to try that first.
