Wideband Wiring Questions
T03KNEE
Re: Wideband Wiring Questions
Post by T03KNEE »
Sorry I should probably mention I haven't begun any actual wiring yet besides installing the aftermarket sensors, I wanna get this down 100% before I cut anything. I would like to install the aftermarket gauges and have them working with the oem pieces functioning if I can.
That is not possible.
T03KNEE
Post by T03KNEE »
So would there be a way I can use oem gauges with the aftermarket sensors?
Asking the same question over and over again will not change the answer.
T03KNEE
Post by T03KNEE »
You're right I'm sorry, I'm just confused but it seems like it'll be fine with the oem parts not connected and tied off somewhere. My car has the luxury of being so old that the fan switch and ECT are separate so the fan will be find and the oem oil pressure switch just tells the oil light when to come on but I'll be able to monitor it myself so it'll be fine. I got the wiring down with your help so I should be good to go
Only thing I need help with now is getting a base tune set up but I can just ask in a new thread so this one doesn't drag on if that's best, I have some aftermarket cams and the car ran like shit with the stock ecu and I wanted to make sure that doesn't do that with the hondata
