Has anyone else had this problem? Can anyone help me?
I still can't find the issue. In WOT, it switches to Open-Cold for no reason, then switches to Closed.
I can't find any incorrect settings or sensors with erroneous data.
STFT Active - in Open Loop
Re: STFT Active - in Open Loop
Post the calibration the datalog was made with
It's similar to the one in the initial post; I've attached a more recent version.
You cannot disable closed loop in the calibration. IT must still have the OEM snsor for closed loop to work correctly and the aftermarket wideband is only used for datalogging purposes. The is setup in the Options, Settings, Lambda overlay tab.
I have the stock O2 sensor, and I don't understand why it's not in "Open-Driving" mode in WOT. I don't intend to disable "Closed loop," just use it for partial pedal operation.Spunkster wrote: Wed Jul 01, 2026 2:38 pm You cannot disable closed loop in the calibration. IT must still have the OEM snsor for closed loop to work correctly and the aftermarket wideband is only used for datalogging purposes. The is setup in the Options, Settings, Lambda overlay tab.
I never touched that setting; I checked both computers where I have FlashPro installed, and they're the same. Should I have "Stock sensor" selected for both options?
As the factory is a wideband sensor there is really no need to use an aftermarket wideband for the datalogging. If you have it set to the stock sensor then it will not be showing data from the aftermarket sensor. This is only used for the overlays.
I still don't understand why it's changing to "Open-Cold"
It probably has to do with the throttle place closing just before hand.
I don't think so. The car continues accelerating to the rev limiter without issue.
Both the plate and pedal remain at 100%.
It should stay in "Open-Driving" mode throughout the entire WOT.
Something is causing this erroneous condition.
