Page 2 of 2
Re: STFT Active - in Open Loop
Posted: Wed Jul 01, 2026 6:10 am
by wal
Has anyone else had this problem? Can anyone help me?
I still can't find the issue. In WOT, it switches to Open-Cold for no reason, then switches to Closed.
I can't find any incorrect settings or sensors with erroneous data.
Posted: Wed Jul 01, 2026 9:17 am
Post the calibration the datalog was made with
Posted: Wed Jul 01, 2026 11:30 am
by wal
Spunkster wrote: Wed Jul 01, 2026 9:17 am Post the calibration the datalog was made with
It's similar to the one in the initial post; I've attached a more recent version.
Posted: Wed Jul 01, 2026 2:38 pm
You cannot disable closed loop in the calibration. IT must still have the OEM snsor for closed loop to work correctly and the aftermarket wideband is only used for datalogging purposes. The is setup in the Options, Settings, Lambda overlay tab.
Posted: Wed Jul 01, 2026 3:08 pm
by wal
Spunkster wrote: Wed Jul 01, 2026 2:38 pm You cannot disable closed loop in the calibration. IT must still have the OEM snsor for closed loop to work correctly and the aftermarket wideband is only used for datalogging purposes. The is setup in the Options, Settings, Lambda overlay tab.
I have the stock O2 sensor, and I don't understand why it's not in "Open-Driving" mode in WOT. I don't intend to disable "Closed loop," just use it for partial pedal operation.
I never touched that setting; I checked both computers where I have FlashPro installed, and they're the same. Should I have "Stock sensor" selected for both options?
Posted: Wed Jul 01, 2026 4:23 pm
As the factory is a wideband sensor there is really no need to use an aftermarket wideband for the datalogging. If you have it set to the stock sensor then it will not be showing data from the aftermarket sensor. This is only used for the overlays.
Posted: Wed Jul 01, 2026 4:26 pm
by wal
I still don't understand why it's changing to "Open-Cold"
Posted: Wed Jul 01, 2026 4:46 pm
It probably has to do with the throttle place closing just before hand.
Posted: Wed Jul 01, 2026 5:20 pm
by wal
I don't think so. The car continues accelerating to the rev limiter without issue.
Both the plate and pedal remain at 100%.
It should stay in "Open-Driving" mode throughout the entire WOT.
Something is causing this erroneous condition.
