Strat up problems with S300 after converting from S200.
Change the load value in the first column - it is going to 30 psi after the conversion. If you can find the value from the original tune put that in, otherwise use 0.100 bar. (To change the value right click on the first column '1'and enter 0.100). If it still stalls then post a datalog. Also, what size are the injectors? 370?
kwuaymaikrup
Post by kwuaymaikrup »
I will try what you said. The injectors are 1000cc. When we first converted it the S300 would change the value to 1333 now it says 370??? What the hell. I will give it a shot. Thanks.
-Ryan
