K-Pro loses connection when Datalog Recording
marcs23
Post by marcs23 »
[quote="Spunkster"][quote="m4nfred"]anybody found a resolution or something to this[/quote]
What cable are you using?[/quote]
I am using the one that came with my K-pro, which I got about 2 months ago.
and what spark plugs are you using? part number?
m4nfred
Post by m4nfred »
stock spark plugs, just new
but what is the part number on the actual plug that is currently in your car?
erikssi05
Post by erikssi05 »
Hondata wrote:The common factor is the Greddy kit. In the past we've found that the kit included non-resistor spark plugs, but it could be that there is something else in the kit which creates a bad ground or inteference. We've asked Greddy for the installation instructions & kit contents, and are looking for a local vehicle with the Greddy turbo kit to look at here.
HEY I WILL BE INTALLING MY GREDDY KIT BY THE END OF THE MONTH AND IM LOCATED REALLY CLOSE BY... IM WILLING TO LET YOU GUY CHECK OUT MY CAR... :D
zirconc
Post by zirconc »
I have the same problem. The ECU works fine when it first out of the box. Then it just gotten worst and worst. Now as long as the engine is on, it will just shut right off. WHen I turn the engine off then unplug and plug in the USB then it will work again. Then turn the engine on and it will lose connection again.
I have tried the cable fromt he box and a Shielded USB 2.0 cable. They all react the same way now.
When it was out of the box I was using the older version of Kmanage. Anything think that might be the problem?
Wills
It is not the version of software. erikssi05: if you have connectivity problems, then contact us. zirconc: check the main ground near the intake manifold, check the type of spark plugs then contact us for a cable with bigger ferrites.
zirconc
Post by zirconc »
The ground for the fuel line has been ,oved to the top of the valve cover and the the other ground is on the timing chain cover. The plug is OBX and here is the what they said about their plug. I have no idea if they have resistor or not. I will go buy some cheap stock plug today and try it.
here is the description:
Increase horsepower and get greater fuel and engine efficiency for your vehicle with these OBX Racing Iridium Spark Plugs! Comes with a 60,000 mile lifetime warranty. Way better than NGK and Denso spark plugs since the cores are completely made of Iridium instead of coated! Easy to install.
Features:
* Iridium cored center electrode
* Extreme spark discharge for optimum combustion
* V Sharpe ground electrode design for high performance engines
* 60,000 mile lifetime warranty from manufacturer defects
* Recommended for High Performance, Turbo, Super Charged, and Racing Engines
marcs23
Post by marcs23 »
Well I still have this problem. As long as I am not wot it stays connected fine. Everytime I try to datalog, soon as I hit WOT, I lose connection. If I just unplug the usb cable and plug it right back in, it connects and is fine. that is until I hit WOT again. And I am using a newer dell inspiron laptop. This is getting annoying since i can not do a wot datalog to street tune. please help.
My mods are listed earlier in this post as well as my plugs
Marc
abp-rsx-s
Post by abp-rsx-s »
I also have the same problem since day one. I can't datalog at WOT.
My laptop is a sony vaio (2 years old) and I'm using the cable that came with k-pro. I have a Greddy turbo kit with ngk plugs.
zirconc: test this stock plugs (not 'cheap' stock plugs, the actual stock plugs).
abp-rsx-s, zirconc & marcs23: have you got the USB cable from us with the extra clamp on style ferrites?
abp-rsx-s
Post by abp-rsx-s »
I didn't request it yet. I'll fill up that form. thanks
aam
Post by aam »
I appologise for this suggestion being a little basic.
I had a similar problem when my K-pro was first fitted, the laptop would go offline after a few seconds or minuets during a datalog, I never even got the car moving!
I found the problem was with the USB plug going into the ECU, When the glove box was closed the back of it pushed against the plug causing it to loose connection intermittently. I ended up twisting the ECU round and putting it in back to front. Never had a problem since!
Try having the glove box open during a datarun and see if it makes a differance.
Again sorry if this is not relevant.
Alan
abp-rsx-s
Post by abp-rsx-s »
Thanks for the suggestion Allen, I'll try that this weekend.
tunerguy
Post by tunerguy »
That same Lotus POS is back and my problem are worse the longer I spend on it the shorter the time period before it goes offline.
I think the HONDATA is a POS.
Can anybody tell me how to keep connected so I can actually tune this car.
Laptop is a Acer travelmate 240 Celeron Processor.
