P28 ECU Problems? HELP!
ranta18
Post by ranta18 »
The gauge is maxed out lean.
Mike Ranta
If the guage is maxed out then it sounds like you either have a major exhaust leak, have an injector stuck closed, or you just need to add fuel in the calibration.
ranta18
Post by ranta18 »
I have the gauge in my car now with the stock ECU. Works perfectly fine. Reads great. Its just when I have the Hondata hooked up that maxes out. Its a D16 non-vtec engine and I have the stock P28 map loaded.
Mike Ranta
Update: Problem has been resolved. There was an error code caused by a damaged IAT sensor.
ranta18
Post by ranta18 »
Spunkster wrote:Update: Problem has been resolved. There was an error code caused by a damaged IAT sensor.
??? It didn't work on two other cars with no codes. I sent my stuff into Hondata. They said both ECU's had lifted tracks from the socketing. Time for ANOTHER P28. :? Hopefully it works after this.
Mike Ranta
