How do I wire in my Wideband?
Laa
Post by Laa »
so you just hooked up the AEM UEGO without the fabrication of that gadget? and then made the custom settings with the voltage chart provided with the AEM UEGO?
Wafler
Post by Wafler »
That is correct. The readings are correct all the way from lean to rich.
Laa
Post by Laa »
Now I have an OBDI ecu with a OBDI-to-OBDII conversion socket with the s300 installed. I'm assuming I just hook up the AEM UEGO to the ELD pin according to the OBDII pin out chart. Is that right or am I wrong?
TurboGSR96
Post by TurboGSR96 »
Bump, makes me feel like there is new light.... I have a buyer for my AEM but id rather not sell it.
585whp/385tq @ 21-23psi E85 Ethanol
OEM GSR Cams & Ignition
TurboGSR96
Again cause I looked in the O2 calibrations in the Smanager & AEM Pro and the PLX M-Series and the AEM both operate @ 0-5v, just gotta find out if there is any voltage offset.
Laa
Post by Laa »
how about an obd1 to obd2 socket conversion ecu? do i just put it on the eld pin according to the obd2 pin out chart?
TurboGSR96
I am assuming you would pull it from the ELD on the OBD1 side.
Laa
Post by Laa »
I meant i have an actuall obd1 ecu with and obd1 to obd2 socket conversion on the actuall ecu itself.
Then you will have to check the wiring diagram for the OBD2 plugs.
smracing
Post by smracing »
Why can't Hondata just create a setting in the software that will accept the 0-5 volts? You are better off having that range of measurement.
TurboGSR96
PLX M reads 0-5v according to my S Manager settings under Wideband/Lamda
