Page 2 of 2
Posted: Sun Aug 20, 2006 8:02 pm
Unless I have misread your posts, it doesn't seem to me that there is a problem. Vacuum at idle varies with engine, cams, idle speed, compression and ring seal, but as a guide 20 inches is good and 21-22 inches is excellent. Low compression turbo engines can be 17-18 inches. If that makes the car idle in column 3 & 4, that is fine. If our tuning guide says your engine is broken if it doesn't idle in columns 1 and 2, tell me and I'll fix the tuning guide.
Posted: Mon Aug 21, 2006 5:21 am
by TurboLS
Well it doesn't say it is broken explicitly, it just says it should idle in those columns. I've been driving the car hard like this for a while, so I know it's not broken, but if it screws up the tuning process, I would like to know. Thanks again for the input.
Posted: Mon Aug 21, 2006 9:21 am
by strider
Mine still idles in columns 3-4 as well. I have cleaned the IACV, adjusted the TPS, tried a different MAP sensor, etc.
Looking back at my datalogs I noticed that past 3000 rpms, when I let off that throttle, it will go to columns 1-2. But once it hits around 1000-1500 rpms it idles in columns 3-4 again.
Is that normal?
I wonder if it is caused by my cams. My compression numbers where decent.
Posted: Mon Aug 21, 2006 10:28 am
Just saying somethign is in columns 2-3 or 3-4 dowesn't really tell us anything unless you tell us what the actual vacuum reading is at idle.
Posted: Mon Aug 21, 2006 10:40 am
by TurboLS
my vacuum reading at idle is 20" using a vacuum pump gauge.
Posted: Mon Aug 21, 2006 11:35 am
by strider
Spunkster wrote:Just saying somethign is in columns 2-3 or 3-4 dowesn't really tell us anything unless you tell us what the actual vacuum reading is at idle.
Thanks Spunkster? that is a good point.
My column 3 = 281 mbar and my column 4 = 406 mbar with the vacuum unit set to ?absolute.? When I changed the setting to in/lbs and ?atmospheric,? column 3 = -21.4 in/lbs and column 4 = -17.9 in/lbs.
If I understand that correctly, that would mean I am in the correct range...right?
Posted: Mon Aug 21, 2006 1:41 pm
That sounds ok
Posted: Mon Aug 21, 2006 2:04 pm
Idling in columns 3-4 is completely normal and the error is in the documentation.
Posted: Mon Aug 21, 2006 3:02 pm
by strider
Thanks for the feedback. One thing less to deal with...
At least in the process I found out that my preset TPS wasn't set correctly.
Sticky for the win!
Posted: Mon Aug 21, 2006 6:44 pm
by sulsa76
Ya'll should make a sticky about this. This thread cleared up a lot of questions for me.
Posted: Sat Sep 09, 2006 5:54 pm
by ben
For reference:
A stock GS-R will pull roughly 22" Hg at 750rpm.
My previous ITR-cammed GS-R engine = 270 to 299mbar absolute (21.9" to 21.1" Hg) at 850rpm. The compression test was 265psi with JDM ITR pistons (std bore), block undecked.
My current Sk2 Pro2-cammed GS-R (.010" over) = 335 to 350mbar absolute (20.0" to 19.6" Hg) at 1000rpm. It did 220psi on a Craftsman gauge with JDM ITR .25OS pistons that are 0.002" above the deck. It does lump and misfire some.
Nice
Posted: Mon Sep 11, 2006 6:04 pm
by sulsa76
Thanks for that Ben, those are some great reference numbers.
