Lambda values not displaying on map @ low load...
TurboLS
Post by TurboLS »
Sorry for the confusion, Spunk. I can view lambda values in Display and Sensors all the time. However, I cannot view them at low loads as datalogged values on the RPM/load map. I will try the TPS to 1% thing and see if that fixes the problem. Thanks for the help.
TurboLS from Team-Integra.net
(703)919-2786 (C)
It has already been tested and the 1% TPS does resolve it...this is a temporary fix until the next revision of software comes out.
TurboLS
Post by TurboLS »
OK, do I switch it under TPS in the Parameters tab or do I switch it in the sensor overlay dialog box?? I tried both and I still get nothing on the RPM/load map. Could you maybe post a calibration that has those settings all filled out>??
(703)919-2786 (C)
You need to adjust the Settings in the TPS section of parameters until your TPS reads 1% at idle. You will need to upload the change after you make it.
TurboLS
Post by TurboLS »
alright, i'll try that. thanks again, and sorry for my lack of conception lol.
(703)919-2786 (C)
