popping at idle
92hb_hb
Post by 92hb_hb »
i've had this symptom too.. i'm running a walbro, rc750s', and an AEM fpr.. I have a fuel pressure gauge on my fuel filter and it reads about 40-42 @ idle.. Is that about right? or should it be lower??
sometimes the popping happens, sometimes it doesnt..
You may need to run the car slightly leaner or slightly richer at idle.
Shmaa
Post by Shmaa »
40-42 is pretty good, pull the vacuum off of the fpr and check it, I try to keep mine a litte under 50psi.
if it is only doing it occasionally you can probably just richen up the idle a tad and that should take care of it.
Before I got a fpr my fuel pressure was over 60psi and I had to run like 12.5 afr's at idle to get it to stop poping.
