Hondata ECU for 00-05 S2000
THe software allows you to put in whatever vin number you would like to.
Fongu
Post by Fongu »
Spunkster wrote:At this time I cannot answer the wideband sensor question. It may work with custom wiring and relays.
Is there an update to this, like a recommended wideband sensor and wiring diagram?
It is designed to work with the stock S2000 o2 sensor. While the RSX o2 sensor technically may be used, it would require changes to the adapter circuit board, which is something we are not recommending or supporting. For the price of a RSX sensor you can buy a whole aftermarket wideband , and feed that into the ECU.
Fongu
Post by Fongu »
I meant the wideband setup for datalogging through the ELD that the product page mentions.
Recommended wideband: PLX.
Wiring: connect the analog voltage output from the PLX to the ELD input (A30 on the S2000 harness).
Garrett_si
Post by Garrett_si »
now release 8)
Malkolm666
Post by Malkolm666 »
Hello, I do already have an RSX Kpro for my swapped K20 EG civic, can I use that KPRO for my S2000-00 and only buy the wiring harness needed from you?
Or do I need to buy the "RSX Kpro S2000-Thing" complete?
Are you wanting to still be able to use the ecu for the EG?
Malkolm666
Why do you ask that?
I dont know, maybe..
It will not work. You will need separate ecu's for each car.
Malkolm666
You?re not answered my question, so I?ll rewrite it;
-If I already have an RSX Kpro, can I use it for my newly bought S2000?
What things do I need to buy from you?
Thanks alot for helping me out on this one! /Malkolm
Yes that ecu and K-Pro can be used, however once it has been converted for use in the S2000 you will be pushing the EG as you will not have a usable ecu for it.
Malkolm666
Okey, how do I order the stuff I need to make it work in my S2k?
You must go through a dealer. Send in the ecu, the ecu is modified and once modified cannot be used any any other vehicle.
Malkolm666
Okey, thats to bad that I cant use my RSX Kpro, and its to bad because there is no dealer here in Sweden. And its to bad because both the AEM EMS and the Apexi Vafc is much more easier and/or cheaper to get and install in the S2000. I think thats boring thu to the fact that your software is alitle bit eaiser to work with. But this time it seems that I?ll choose another route.
