plx with s300?
mark3000
Post by mark3000 »
TurboLS wrote: and then adjust the offset in Hondata until they match.
Where in Hondata are you seeing the A/F ratio (besides when datalogging) I know where to adjust it, just dont know where to check it.
mark3000
Post by mark3000 »
found it, under sensors, change units from wideband to A/F
92hondalude
Post by 92hondalude »
so should i run the cap?
or disable the o2 heater
There is no cap. You can either disable the o2 heater or add a resistor to allow the ecu to think the heater is working.
92hondalude
oh ok.
but what about these caps i got.
should i run them or not.
