daughterboard com error
Try clearing security then uploading a completely new calibration and see if the problem still occurs.
kornsined
Post by kornsined »
did that when I tested it on a different car and the problem never occurred.
2004 Civic EX Coupe
K20a3 RSX spec, Greddy turbo kit w/FMIC, Apexi WS II Turbo muffler, 3" custom ... mandrel exhaust, KPRO = 230.03WHP 213.16WTQ
kornsined
Post by kornsined »
Again the problem happens. My ecu was sent to Hondata and is fine. My charge system was tested by Honda and is fine.
2004 Civic EX Coupe
Sounds more like you are hitting a lean cut. Can you provide a datalog and the calibration from when this happened?
kornsined
Post by kornsined »
Thanks for the info.
2004 Civic EX Coupe
What is the battery voltage at the ecu when the car is cranking?
kornsined
Post by kornsined »
I finally got this problem fixed. Fuel pump relay was burning out. Replaced it and all is good.
2004 Civic EX Coupe
