primary o2 voltage stuck at 0v no codes
ep3lookslikeyou
Post by ep3lookslikeyou »
here are the datalogs of 5th gear cruising and idle fully warmed up. i also did one more pull in WOT.
this is all under the same calibration
PatAttack
Post by PatAttack »
BUMP! i sent you my kals and logs as well. Hoping for an answer soon, any kind of answer.
Have you tried your ecu in a known good vehicle? If the ecu works in a nother vehicle try also swappign the o2 sensor. If everything is still good then you must have a wiring problem in your car.
