H22 Turbo w/1000cc Precisions need startup cal.
Colocho19
Post by Colocho19 »
thanx man your a life saver! im gona load it to my hondata see how it goes ill let you know was soon as i can!
Colocho19
Re: Yeah here is an update with the EBC working
Post by Colocho19 »
cardinal811 wrote:
Colocho19 wrote:hey is does any one still have the Blundell Tuned 15psi.skl file since the link does no longer work please need that map asap help!
my setup is:
Hondata S200
H22a
Garret Gt40R
AEM Fuel rail
Custom Throthle Body and Intake Manifold
Custom Turbo manifold
1000cc Precsion Injetors
Stock preasure regulator
3.5 bar map sensor
Sleeved
After market pistons, rods, crank
Moroso oil pan
aftermarket LSD, Twin disk clutch
wait im sorry but these calibrations are for s300 not for s200 im sorry ive must have missed that from the begining is there any way that you can convert the DAVE FINAL MAP.skl to be able to put it on a s200 please i really read it so bad, thanx for your time and help!
bigduce
H22 tune for 20psi on 1000cc injectors
Post by bigduce »
I have the same problem, i cant downlode that map. it doesn't work. If you can email me the map to boricarlos@hotmail.com it will be appreciated. I have a S300
Thanks,
Bigduce
H23V-tec
Colocho19
Re: H22 tune for 20psi on 1000cc injectors
Post by Colocho19 »
bigduce wrote:I have the same problem, i cant downlode that map. it doesn't work. If you can email me the map to boricarlos@hotmail.com it will be appreciated. I have a S300
Thanks,
Bigduce
the last map works fine try it out but im gona send it to you anyways give me a minute.
cardinal811
Post by cardinal811 »
You realize I spent over $2000 for that full tune including 5hr's street and I belive 13hrs on dyno period of three sessions over and over because I kept on making improvements to the flow of the intake and exhaust . I messed up by not claying my block/head for cam/valve tolerances. I we went slowly. Also this is with the pro one S2 cams. THEY KICK ASS. Any of you from around Indiana?
I'd love to meet up with some locals
Colocho19
Post by Colocho19 »
so there's no way you can help me get that map into an s200?
cardinal811
I believe that you need to contact HONDATA and ask them how to convert. Because I know that you can take S200 map and load into the S300 software just fine, but going the opposite direction I dont know.
It cannot be converted back to an s200 from an s300.
Colocho19
Post by Colocho19 »
Spunkster wrote:It cannot be converted back to an s200 from an s300.
but can it be done manual?
cardinal811
POSSIBLY but the S200 has different features and parameters setup, AND WHY HAS MY MAP NOT BEEN STICKIED? haha :D
Colocho19
Post by Colocho19 »
oh ok ill just see were i can get an s300 from anyways the s200 does not belong to me i just wanted to get my car runing already and hear how it sounds and to check everything else like leaks and make shure the harness was properly wired before i go get it tuned. Thanx for the help tho if you come across a map for an s200 dont forget about me.
Colocho19
My HondaLogger
Post by Colocho19 »
Well I decided to do a hondalog on my car and heres what it came up to be: i got for error codes Crank Angle Sensor, Throthle Position Sensor, Intake Air Temp, Idle Control can any one please PLEASE help me fix all of this problems im new to hondas and hondata and my car wont go past 2k rpm does any one think that all those errors are causing my car not rev past 2k rpm? well i attached the file so any one could look at it, any suggestions are welcome, Thanx in advance!
This is what i recorded when i started the car and it just shut of.
cardinal811
Crank angle sensor? OBD2 pal
Colocho19
Post by Colocho19 »
cardinal811 wrote:Crank angle sensor? OBD2 pal
im sorry but im new to honda and hondata, what exactly do you mean?
cardinal811
What year is your motor? And when you know that, you need to research online. Man, seems like your wanting handouts
