ROMeditor 4 does not save my bins
ROM Editor 4 tuning software questions and answers.
Describe exactly how you have everything hooked up.
V-Spec race development
Post by V-Spec race development »
ok, as I described on my previous post, I'm using Dell notebook w/ vista. I downloaded the latest RE4 and i hooked up the cable and followed on how to install driver. Once that was done, I reboot the system and open RE4 and checked for updates and everything are up to date. Then I hooked up the re4 cable to one of the usb port and the other side w/c is the big side hook up to the blue box or interface box serial # 4132. Then the little cable from the blue box to the ecu. Now for the transtronic romulator, I have the keyspan usb to serial adapter. I hooked up the usb side to my notebook on another port and the romulator hooked up to the ecu with the red ribbon facing the wire harness of the ecu. I went to my device manager and see where/what com port the keyspan at and it says com4. So then I went to option, setting and click the tab s200 and checked "Rom editor 4 datalogging" checked Transtronics romulator and set to com4 as what it was showing on my device manager. I have the pocket programmer so I checked that as well. On the general tab, the box that says "file association" is not check. I had check that box before but it did not do anything as far as loading or saving a base map. So now, I picked a base map w/c was for stock p72 and tried to upload it while the ignition is on but not the engine running and it would always says " usb/serial cable cannot be detected" I also tried using the Ostrich romulator to this notebook w/ no success. I also tried using another laptop w/c is using windows xp, download the latest software and installed driver and updated and follow the instruction on how to load a calibration and still no go.
Have you ever used any other USB to serial adapters, or any DIY kits or software for tuning....like megasquirt?
I have not tried using other usb to serial adapter, what do you recommend. I tune people's car w/ S300 w/ no problem. I have tuned few other cars w/ the old s200 rom editor 3 before I upgrade to re4. I never use any other diy kits or any other software for tuning.
Please call us for an RMA number and we can test it.
Thank you. I'll be sending it to your way today.
