Hondata 4 Bar Map Sensor
Tchleung
Post by Tchleung »
Well I got my Hondata/Omnipower 4 bar map sensor. First thing I did was pressurize it to 30psi holding the sensor in my hand. helf fine there but 35 psi blew the cases apart. it's not a big deal tho, looks like cheap permatex clear silicone holding the halves together, but again, this is me testing it in my hand, not botled down holding it together. so I jsut JB welded the cases togetehr inside and bolted it down. No problems :)
The map sensor is designed to be bolted to the manifold. When installed correclty they have been tested to 120psi without failing.
