S2000 K-Pro 02 sensor high voltage?
S2KPRO
Post by S2KPRO »
Spunkster wrote:We are looking into a permanent fix for this and will update you when we have a resolution.
I should add that when I left my tuners shop my CEL was on. I then went to the gas station filled up and it never turned back on for the 15km drive to my house. The next day I am driving to work and the light comes on within 15 seconds of driving.
I went back to my tuner today to have it scanned and the same code came up again.
Not sure if this bit of detail will help, hopefully it can lend a hand in understanding the problem.
S2KPRO
Post by S2KPRO »
Are there any updates from anyone at Hondata that they can provide, any insight to this fix this problem at all? I would hate to go back to my mechanic and have them try and troubleshoot and spend more money and time etc.
1. Download the beta version: http://www.hondata.net/updates/KManagerV1-2-9.exe
2. Update ECU.
3. Datalog from a cold start as soon as the engine fires.
4. If there are problems, post the datalog here.
5. Don't panic.
S2KPRO
Post by S2KPRO »
Hondata wrote:1. Download the beta version: http://www.hondata.net/updates/KManagerV1-2-9.exe
2. Update ECU.
5. Don't panic.
The software that was used for my tune was v. 1.2.3.5 I assume the one you have posted above is different than the one I have?
Thanks for your help.
Garrett_si
Post by Garrett_si »
I finally installed and test my own S2000 K-pro on my 2004 s2k
the problem is the same
O2 sensor high voltage
and after disable 02 sensor, 02 sensor heater, and using secondary...
I have the 02 sensor low voltage
I understand that Hondata try to find a way to fix it
But I think I will convert mine to use the RSX wideband 02 sensor
Please try the beta version above.
Garrett_si
I try it today when tuning my car on the dyno and with de 1.2.6 version the probleme still the same
low voltage 02 sensor CEL code
1.2.6 is not the new version or the beta listed above.
Garrett_si
sorry I used 1.2.9 that you post here
What exactly have you done once you downloaded the new software?
Garrett_si
Spunkster wrote:What exactly have you done once you downloaded the new software?
I installed it to replace the last version
I open my cal, and upload it in my K-pro
With your calibration loaded and a datalog of the problem go to File and click on email. This will email us a detailed problem report.
Garrett_si
Spunkster wrote:With your calibration loaded and a datalog of the problem go to File and click on email. This will email us a detailed problem report.
Ok
My outlook open when I did it, and there is no email adresse wrote
support at hondata.com
Garrett_si
Send
