Boost Control
rkhan
Post by rkhan »
Hi
Quick Question
What are the dimensions of the muffler on the solenoid, as I am trying to source one .
92hondalude
Post by 92hondalude »
how do i know if my s300 has the boost option on it? i have had it since it came out and for some reason i think it doesnt have it on there.
1/8" NPT
All S300s can operate boost control...it is a software setting. However, the ECU must have components added for it to work.
http://www.hondata.com/help/smanager/bo ... st+control
stedciv
Post by stedciv »
ok so i played around with my boost control settings a little bit today
when i set the fixed duty cycle at 35 i get 14lbs of boost
when i set it to 10 i get 12lbs.
i want to get this put in the pressure vs duty cycle so i can run boost by gear. which values will i change? the pressure or the duty cycle?
will i use negative values if i want to set it to 7lbs for 1st and 10 for 2nd since i am getting 12lbs at just 10% on fixed?
You enter both the duty cycle % and the boost level. You cannot enter negative numbers unless you have a Delorean and a flux capacitor.
