Odd fuel trim issue- Kpro on S2000
0piston
Post by 0piston »
I was just searching through the forums for a similar problem on my car, Thank-you very much, your beta fix works!!! :) at 0%tps - 4%tps it works excellent no more hesitating and leaning out on closed loop
Thank you for the feedback.
Ramocheese
Post by Ramocheese »
The beta fix seemed to work for me too. I put the new o2 sensor in and left it on the old tune to make sure I was still having that issue, and i was.
I updated to the new firmware and everything seems to be working great! :)
Jon B.
'04 S2000
Great.
0piston
Post by 0piston »
0piston wrote:I was just searching through the forums for a similar problem on my car, Thank-you very much, your beta fix works!!! :) at 0%tps - 4%tps it works excellent no more hesitating and leaning out on closed loop
I spoke to soon, I tried it that day and everything worked awesome. Yesterday I was driving and it started acting up again. Would it be possible to take the closed loop 02 input voltage from the ELD input (wideband)? I think that would solve my problem because my voltage readings from there are perfect!
If you are trying to run closed loop off of a wideband 0-5v signal it will not work.
