SManager V1-4-2 [Updated 6-23-2009]
Quade
Post by Quade »
hmmm........Well what I did was to change the units on the map tables (Options, settings, Units) to kpa and it was like in the 70s in the idle range. I guess that threw me off cuz I was looking for the values to be around the 20s/30s. So is it possible that when the units are changed to kpa the values in the map columns are wrong?
fly_n
Post by fly_n »
Quade wrote:hmmm........Well what I did was to change the units on the map tables (Options, settings, Units) to kpa and it was like in the 70s in the idle range. I guess that threw me off cuz I was looking for the values to be around the 20s/30s. So is it possible that when the units are changed to kpa the values in the map columns are wrong?
now change your vacuum unit reference from atmospheric to absolute under the same tab.
Quade
Post by Quade »
I should have figured that out. :(
kinetics
Re: SManager V1-4-2 [Updated 6-23-2009]
Post by kinetics »
Hondata wrote:If you suffer jerkiness at very light throttle when the injectors cut off, try changing the MAP value to around 15 kPA. This only seems to affect some people, usually with high compression engines.
Are you referring to the Load Index value, or the Overrun values?
ITR 1102
Post by ITR 1102 »
is there an archive of older versions?
I don't have the previous release installation file saved, but need to use it. The latest release is causing problems. (connects and will update ecu with changes, but changes to the tables have no affect). This comes and goes and is not consistant.
Where can I get it?
The Software page has the same filename as the beta version now. I assume it to be the same.
1.4.2.0 is the current release version and is not beta.
