S2000 AP2 Kpro ECT dash gauge display problem
edomund
Post by edomund »
It will blink on for a split second & then remain off for several seconds then blink again. I don't see a clear pattern. What should I be looking for?
What is the correct status of the light?
Any thoughts about what I posted?
Thanks,
Ed
AP2 S2000 Turbo
edomund
Post by edomund »
Any ideas?
AP2 S2000 Turbo
Do you know anyone near you that has a K-PRo in their S2000 that you can swap ecus with for testing?
edomund
Post by edomund »
I posted a thread on the s2ki Sacramento area sub forum, so we'll see if anyone does. But I already know most of those guys & none of them are running Kpro.
Could you please tell me the correct status of the adapter?
Without knowing that how can I tell if it's correctly lit?
If I can't find someone with a Kpro near me can you guys send me another Kpro to try?
AP2 S2000 Turbo
When it was here it was behaving as it should this is why I would like you to try it in another vehicle if possible. The only other person that had issues with this had air bubbles in his cooling system and had to bleed it.
edomund
Post by edomund »
I will try to find someone, as this would rule out any problem with my vehicle.
What doesn't make sense is I didn't have a problem when my factory ecu was in & I haven't touched the cooling system since I changed ecu's.
Also when I sent it in the 1st time the adapter board light NEVER came on (ect ALWAYS read 1 bar) & now it works sometimes.
Also if it was air bubbles or something to do with the sensor wouldn't the voltage change when the ECT gauge dropped off? The voltage is constant even when the ect gauge drops down to 1 bar.
Again, what is the adapter light supposed to do? Is it supposed to stay lit all the time?
Edit:
I think I may have found someone in my area.
AP2 S2000 Turbo
edomund
Post by edomund »
Nevermind the guy is running AEM who volunteered.
What can I do if I can't find anyone?
Also can someone please tell me what the adapter light is supposed to be doing when operating correctly?
AP2 S2000 Turbo
Please just send it back to us an we will arrange a test in a vehicle here. Please send it using the same RMA number you were given before. The status of the LED will not help trouble shoot anything at this time.
edomund
Post by edomund »
OK thanks I appreciate it.
I'll give you guys a call as to when I'm sending it so you can set up the test vehicle.
thanks,
Ed
AP2 S2000 Turbo
