Major drivability problems after software update
BabyNSX
Post by BabyNSX »
hmmmm... So does this mean that the cold temperature compensation parameters canot be used to stop the ECU from fighting with the low-temp thermostat? If this is the case then I guess I'll have to re-install the OE one.
You should be using an OEM thermostat.
