FlashPro Requests
Holly_2.0
Re: FlashPro Requests
Post by Holly_2.0 »
{2018+} Honda Accord 2.0T auto 10th gen
i would like some more mod support right now there's only flex fuel. though you can install race downpipes, less restricting/bigger exhaust systems, cold air intakes, and the ctr turbo upgrade thats already discussed on your website.
Vtek
Post by Vtek »
Hi i would like to buy my dad a flashpro for his 2019 cr-v 1.5t 6mt is there any chance these will be supported in the future? I have a flashpro myself for my fk8 so if i needed to pull any info from the cr-v i could use my one, thanx.
Jeremy.
I do not believe that there is a manual 2019 CRV.
Vtek
Post by Vtek »
Yes there is a manual cr-v 6mt
Vtek
Post by Vtek »
In europe its available as a cvt or 6mt, Any chance the cvt version would work on it?
arnoldod
Post by arnoldod »
If possible, please add following preset for all Civic 1.5T (206+) calibrations as part of modification:
  • Preset for throttle response sensitivity ranging from normal, moderate, and high.
  • Preset for better turbo response and turbo spool ranging from stock, improve 1, & improve 2.
  • Preset for turbo boost ramp ranging from stock, improve 1, & improve 2.
Thanks!
Vtek
Post by Vtek »
Spunkster wrote: Wed Jul 08, 2020 3:07 pm I do not believe that there is a manual 2019 CRV.
I suppose that means there is no calibration since you guys are unaware of its existance, is there a way of making the cvt calibration work or is there no way of upgrading the cars ecu?
sirgrumble
Post by sirgrumble »
As a learning experience, I want to compare different calibrations
provided with Flashpro for the Civic Type R 2017+. I would like to
do this by printing out all of the calibration values so that I can
see everything at once, and mark differences up on paper.
Is there a facility in the software that will print out the entire
contents of the calibration?
If not, is it possible to decode the fpcal files and print them out
with tooling of my own?
Vtek
Post by Vtek »
Would the crv 1.5t cvt calibration work with the crv 1.5t 6mt? Or would the ecu have some of the cvt stuff conflicting with the calibration
This is not supported at this time.
sirgrumble
Spunkster wrote: Mon Jul 20, 2020 11:00 am This is not supported at this time.
What is not supported?
Any manual transmissions CRV's
Julianobelluardo
Post by Julianobelluardo »
Instant jailbreak for 2020 FK8 !
davidato
Post by davidato »
Is it possible to disable hill start assist from the ECU? I had it on my Subaru and was able to disable it. If it is possible, consider it a request from me!
myuser
Post by myuser »
Include the FileName uploaded in Datalog
Example: Steps...
  • File uploaded A.fpcal;
  • Save Datalog 001, 002, 003;
  • File Upload B.fpcal;
  • Save Datalog 004, 005, 006;
  • Delete All Logs
The datalog001 (cal A and B have the same name); Saving in FP could save the FileUploaded and/or DateUpload, to be able to know the difference between same name datalogs.
Datalog saved with Variable always incrementing.
Example: instead of datalog001, the file saved always use Internal Variable that Increments, file could be dat0003001, were 0003 is the internal variable, always incrementing.
With this way we always can see the diference between two datalogs with the same name and have a timeline.
