Page 19 of 29
Re: FlashPro Requests
Posted: Sun Jun 28, 2020 12:29 pm
by Holly_2.0
{2018+} Honda Accord 2.0T auto 10th gen
i would like some more mod support right now there's only flex fuel. though you can install race downpipes, less restricting/bigger exhaust systems, cold air intakes, and the ctr turbo upgrade thats already discussed on your website.
Posted: Wed Jul 08, 2020 2:49 pm
by Vtek
Hi i would like to buy my dad a flashpro for his 2019 cr-v 1.5t 6mt is there any chance these will be supported in the future? I have a flashpro myself for my fk8 so if i needed to pull any info from the cr-v i could use my one, thanx.
Jeremy.
Posted: Wed Jul 08, 2020 3:07 pm
I do not believe that there is a manual 2019 CRV.
Posted: Wed Jul 08, 2020 11:14 pm
by Vtek
Yes there is a manual cr-v 6mt
Posted: Sat Jul 11, 2020 4:40 am
by Vtek
In europe its available as a cvt or 6mt, Any chance the cvt version would work on it?
Posted: Mon Jul 13, 2020 3:41 am
by arnoldod
If possible, please add following preset for all Civic 1.5T (206+) calibrations as part of modification:
- Preset for throttle response sensitivity ranging from normal, moderate, and high.
- Preset for better turbo response and turbo spool ranging from stock, improve 1, & improve 2.
- Preset for turbo boost ramp ranging from stock, improve 1, & improve 2.
Thanks!
Posted: Mon Jul 13, 2020 11:17 pm
by Vtek
Spunkster wrote: Wed Jul 08, 2020 3:07 pm
I suppose that means there is no calibration since you guys are unaware of its existance, is there a way of making the cvt calibration work or is there no way of upgrading the cars ecu?
Posted: Sat Jul 18, 2020 9:02 am
by sirgrumble
As a learning experience, I want to compare different calibrations
provided with Flashpro for the Civic Type R 2017+. I would like to
do this by printing out all of the calibration values so that I can
see everything at once, and mark differences up on paper.
Is there a facility in the software that will print out the entire
contents of the calibration?
If not, is it possible to decode the fpcal files and print them out
with tooling of my own?
Posted: Sun Jul 19, 2020 7:05 am
by Vtek
Would the crv 1.5t cvt calibration work with the crv 1.5t 6mt? Or would the ecu have some of the cvt stuff conflicting with the calibration
Posted: Mon Jul 20, 2020 11:00 am
This is not supported at this time.
Posted: Mon Jul 20, 2020 11:35 am
by sirgrumble
Spunkster wrote: Mon Jul 20, 2020 11:00 am
What is not supported?
Posted: Mon Jul 20, 2020 11:58 am
Any manual transmissions CRV's
Posted: Sun Aug 02, 2020 5:05 pm
by Julianobelluardo
Instant jailbreak for 2020 FK8 !
Posted: Tue Sep 01, 2020 11:52 pm
by davidato
Is it possible to disable hill start assist from the ECU? I had it on my Subaru and was able to disable it. If it is possible, consider it a request from me!
Posted: Sun Sep 13, 2020 2:24 pm
by myuser
Include the FileName uploaded in Datalog
Example: Steps...
- Save Datalog 001, 002, 003;
- Save Datalog 004, 005, 006;
The datalog001 (cal A and B have the same name); Saving in FP could save the FileUploaded and/or DateUpload, to be able to know the difference between same name datalogs.
Datalog saved with Variable always incrementing.
Example: instead of datalog001, the file saved always use Internal Variable that Increments, file could be dat0003001, were 0003 is the internal variable, always incrementing.
With this way we always can see the diference between two datalogs with the same name and have a timeline.
